Results 1 to 6 of 6
Thread: corrupted data/tune
    Lifetime Member limited cv8r's Avatar
    May 2005
    Default corrupted data/tune
    Tried to clear some DTC's a couple of days ago,car was running fine up to this point,clicked the clear DTC's icon in scan tool,car coughed , farted ,then died. Had to hold throttle open to get car to start, car would not idle,surged and carried on like a POS. Had to full flash a known good tune to RR to get it to run right.Any one else had any dramas with RR and corrupted tunes?
    Oct 2004
    I've not seen anything like that reported previously. When I had the LS1 I ran a RR in the car full time for probably 2 odd years and the only issue I had was the known issue of have a powered laptop. I would probably never ave cleared DTCs on it though; have you done that before without issue?
    Andrew
    EFILive Crew
    Oct 2006
    I have had a strange issue where I flashed in the tune and the car ran like crap. Read the tune out & couldnt find a fault. Reflashed the same tune back in & everything was fine.
    I also have never tried clearing DTC's while running. If I remember I will give it a go once I get the RR sorted again.
    The Tremor at AIR
    May 2005
    The RR runs good 99% of the time and one of the best things I've invested in,but it does have a mind of its own sometimes.This is the first time I can remember it goofing up with a DTC clear,I have had other times using the scan tool that it has done the same for no reason,and then theres the odd ocassion it has just done it because it can. 2 different RR's so I can't really say it's a dodgy RR either.
    Jan 2007
    It's done it to me before also...but....not since I got rid of the Ribbon cable!
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Lifetime Member N0DIH's Avatar
    Jan 2006
    I use TC2 and I have had it do it to me once, basically if there is anything going on that distrurbs power at all, it can mess things up.
    I tried to reflash and it didn't work, so I read back, then flashed in, and worked fine. Has happened 1 or 2 times, once was that I turned on ignition during the RR flash (I was at the track and couldn't hear and wasn't thinking and hit the stater. Blew away VIN and CASE Learn.... GRRRRR
    I owned a Ford once, ONCE.......
  1. can .tun files get corrupted?
    By Aloicious in forum General (Petrol, Gas, Ethanol)
    Last Post: July 2nd, 2008, 12:16 PM
  2. Do I need a PID to LOG serial data?
    By Chalky in forum FlashScan V2 BB Logging
    Last Post: May 15th, 2008, 11:16 PM
  3. L92 Data log
    By etmotorsports in forum Gen IV V8 Specific
    Last Post: January 26th, 2008, 05:04 PM
  4. Scan Data vs Tune maps? HELP
    By Wichita Dyno in forum Gen III V8 Specific
    Last Post: September 25th, 2007, 05:48 AM
  5. linking scan data to tune file
    By a78turbo in forum Duramax LLY
    Last Post: March 14th, 2006, 04:53 PM
