Results 1 to 10 of 13
Thread: LM-1 AFRs in Scan off the scale.
    Jan 2005
    Default LM-1 AFRs in Scan off the scale.
    Well it's me again, the cursed or ????
    Using the AutoVE tutorial and my LM-1 controller, my AFRs in scan data and Dashboard are in the 40's.
    Volts/AFRs are set correctly in Logworks2 per the EFI info. The LM-1 controller AFR read out is correct and what you'd expect to see.
    C=Green, D=ground, E=red wire.
    0.05V=10AFR, 4.5V=18AFR.
    I've noticed that those settings don't always stay after set in LM programmer V3.04.
    This is starting to really try my exceptional patients.
    Thanks, Curt
    99C5, mn6, Vortec T trim, Snow meth injection, AFR 205s, ARP studs,Comp 224*112*+2*.580", YellaTerra RRs, PRC Ti's w/dbls, Supermaxx LTs, No Cats, Corsa Indys, LS6Intk, Hurst, Fikse Aro18"s. Pilot Sports 315/30,265/35, 04ZO6 Shocks Hotchkis bars, EBC YellowStuff pads, SS hoses, LM-1, EFILive, 2002 OS. RPS dual disc Clutch, DTE Strut Brace & output shaft.
    By default, EFILive expects the LM-1 to be set up as:
    0V = 0AFR
    5V = 50AFR
    The LM-1 formula in EFILive's sae_generic.txt file is:
    {EXT.AD1}*10
    where {EXT.AD1} is the voltage output from the LM-1 unit.
    If you set your LM-1 as:
    0V=10AFR
    5V=20AFR
    Then you could either:
    1. Change the LM-1 default formula in sae_generic.txt to
    {EXT.AD1}*2+10
    OR
    2. Use the PLX PIDs which are already set up for that range.
    Jan 2005
    0V = 0AFR
    5V = 50AFR
    {EXT.AD1}*10
    0V=10AFR
    5V=20AFR
    {EXT.AD1}*2+10
    OR
    Paul, thanks for the come back and a solution. I'll jump right to it.
    Thanks you, Curt
    Oct 2003
    I did #2 above rather than correcting the calculation for the LM-1.
    2003 Silverado SS
    N/A: 14.257 @ 94.63 mph
    N2O: 13.200 @ 102.3 mph
    Jan 2005
    Quote Originally Posted by deezel
    So did I and in EFIScan data, the AFRs are one whole AFR high as compared to what the controller read out is. The comanded AFRs agree with the LM-1 controller read out. 14.7 and 14.7, data reads 15.7 +or-.
    Curt
    Is this the same setup for the LC-1? I finally got my AutoTune setup today and the actual reading did not match the readings off the dynos WB.
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Jan 2005
    [quote="curtbriggs"]
    Curt[/quote
    I tried to reset the LM-1 today using 0Volts=0-AFR and 5Volts=50-AFR in Logworks2 and the system wouldn't allow it. I reset 0V=10 & 5V=20AFR and the read outs in Scan Data were now correct with the PLX PID. I reset in the car with the system on 12 Volts and followed the procedure in Innovate manual, pg 12. The setting didn't change at the end of logging, even after turning the controller off.
    Lifetime Member mistermike's Avatar
    Dec 2003
    There may be a voltage offset, which is usually due to grounding (earthing) issues. The Logworks indication will not be affected by this. Logworks should track your dyno WB pretty close if both sensors are properly calibrated. The place to look in EFI Live is the actual voltage at the A/D converter in the Flashscan cable. This can easily be observed on the live data page without having to build a gauge for it. This voltage should agree with what you would measure from the analog 2 output of the LC-1 controller using a high precision digital voltmeter which has been properly zeroed out. If there is a discrepancy, first thing to do is to check your grounding, particularly that the signal bearing ground is not connected at the same point as the O2 heater ground. Voltage offsets can be compensated for by altering the LC-1 setpoints and / or tweaking the LC-1 PID in the scan tool.
    http://www.innovatemotorsports.com/f...ead.php?t=2489
    Copied from LC-1 manual:
    8.9 Analog Output tricks/hints
    Sometimes there is a ground offset between the device that receives the analog output voltage
    and the LC-1. This can be especially true if the System ground is not connected to the same
    ground as the measurement device using the analog out. Both devices reference different
    grounds and therefore see different voltages. So to compensate for the ground offsets the analog
    output voltage points have to be shifted by the ground offsets. To measure what the real ground
    offset is, you can program the analog outputs temporarily to output a flat line voltage by entering the same voltage in both fields for the two analog out programming points. This way the analog
    output voltage will be fixed, independent of current AFR and can therefore be measured and
    compensated for easily.
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Jan 2005
    Mike, thanks for the information, it's greatly appreciated. I grew up down the road from you in Canfield.
    Cheers, Curt
    Jan 2005
    The ground info from Mistermike was informative except the unit is a standalone sensor used to provide data to the ECU. I wonder if it's ground problems apply to the LM-1.
    In the Innovate forum is a link to an article by Klaus that was a very good refresher for automotive electrical system ground problems and causes.
    http://www.innovatemotorsports.com/r...-grounding.php
    Cheers, Curt
  1. 1/6th scale SBC that runs...!!!
    By joecar in forum Lounge
    Last Post: February 19th, 2009, 08:08 AM
  2. VE table scale up by how much?
    By queso in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2007, 12:23 PM
  3. Scenning just AFRs
    By oztracktuning in forum General
    Last Post: May 15th, 2006, 12:12 AM
  4. AFRs and Turbos
    By oztracktuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 27th, 2006, 03:44 PM
  5. Blue Grey scale block.
    By curtbriggs in forum General
    Last Post: November 28th, 2005, 04:04 PM
