10-11 bar is 147 to 161 psi. That's fine. Rocker torque is OK. Oil flow sounds good.
Chuck L.
CODY Motorsports
Fuel Injector Service
Madison, GA.
706-342-3152
770-265-5144 [C]
Check to make sure that the front o2 harnesses are not switched left to right making the pcm dump fuel to a bank IT sees as being way to lean and pulling fuel from a bank that it sees as to rich. just a thought. My .02 deposited
00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
