Look at the leads where it goes into the board, then look at the other side of the board, they should be like a mini socket, should just pull out. mine came uninstalled. IF yours is newer than 2.5 years ago, might want to ask Craig if the batt comes out, but I bet it does. Look for solder down in the sockets/legs for it. Should be 1 lead on one side and 2 on the other. Just don't pry on the board or IC's, they can and will break, and if the bond wires or die gets force, it is all done.....
