i'm trying to figure out which output to use. I've read about every thread i could find and i'm still confused
1. the efilive tutorial is written for a 7 wire setup and mine is 6 wire.
2. innovate's instructions state that yellow output(number1) is the simulated narrowband wire, but on the tutorial it says use the yellow output number 2????????? that doesn't make sense, which one is right?
3. for the calibration the tutorial says set output 2(yellow?-not right) to 1 volt=10afr and 2 volt=20afr.....innovate's instructions say that brown is #2 and that it is setup at 0v=7.35afr, and 5v=22.39afr
please someone help me out which one do i use, both instructions contradict each other!!
