okay...here is my problem
i had a 99 ls1 pcm go bad in my car, this was after licensed and flashed multiple times.
so fast forward till today. i had the pcm repaired, put it back in the car, pulled the tune out and edited the maps and engine codes back to where i was with the other pcm. flashed it back into the car fine. turned the ign on and wanted to check my idle pids to start tuning the car again. most came up invalid and then efilive wanted me to re-license the pcm.
what do i go to get control of the pcm again. i have flashed this pcm and now its asking for a new license????
