Results 1 to 8 of 8
Thread: help needed...pcm asking to be licensed again
    Jul 2005
    Default help needed...pcm asking to be licensed again
    okay...here is my problem
    i had a 99 ls1 pcm go bad in my car, this was after licensed and flashed multiple times.
    so fast forward till today. i had the pcm repaired, put it back in the car, pulled the tune out and edited the maps and engine codes back to where i was with the other pcm. flashed it back into the car fine. turned the ign on and wanted to check my idle pids to start tuning the car again. most came up invalid and then efilive wanted me to re-license the pcm.
    what do i go to get control of the pcm again. i have flashed this pcm and now its asking for a new license????
    I notified Tech Support.
    Oct 2004
    Can you please provide details of software version used and if applicable FlashScan v2 firmware? As of this post the latest software version is 7.5.6 Build 117 and FlashScan v2 firmware is 2.06.35 (provided by the 8.1.2 Build 97 software). All software is available here: http://www.efilive.com/index.php?opt...=48&Itemid=133
    Can you also please email to me (support@efilive.com) these two screenshots:
    - Screen resulting from following this KB (http://support.efilive.com/kb_articl...2143-YUOG-8049)
    - When connected to your PCM go to the Tune Tool and select the 'Flash->Show PCM info' menu option, choose the correct controller and then click te 'Get Info' button
    Andrew
    EFILive Crew
    Quote Originally Posted by steve40 View Post
    That is not really making much sense, you don't need to license the PCM to scan it, the license process is only applicable when flashing, which you said you were able to do.
    Jul 2005
    i will get you the info tonight after work.....thanks!
    Jul 2005
    info sent
    Jul 2005
    thanks for you help...was able to get the pcm going again.
    It's all working......cool!!
  1. Help needed using DVT on a t42
    By MyM8V8 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 10th, 2009, 07:12 PM
  2. Help Needed.
    By SV8346 in forum FlashScan V2 BB Logging
    Last Post: January 9th, 2008, 09:31 AM
  3. MAP changes needed with big cam?
    Last Post: September 9th, 2006, 10:20 AM
  4. Licensed PCM now unlicensed?
    By PSWired in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2005, 08:43 PM
