Results 1 to 6 of 6
Thread: no tach output
    Jul 2005
    Default no tach output
    i got a 99 ls1 pcm running a 6.0 in a 97 (lt1) style firebird. the tach has work previously. just swapped in a 99 pcm to see how it compares to the 01 one for the transmission.
    anyways everything is working cept for the tach. the scan tool does see rpm, just nothing to the dash
    any ideas? not really sure where to look. the rest of the dash does work. i do have to do a case relearn, would that affect the tach?
    Jun 2007
    No that shouldn't effect anything. Theres a setting in system for tach output if I remember correctly. Why didn't you just reflash the pcm instead of swapping them? Check your connectors on the computer make sure no pins are missing or bent or pushed out. I can't remember if the tach has a fuse it may. It's in system>tach>parameters. Your values should be tacho pulses hi 6, tacho pulses low 6, yes enabled.
    cosmos purple 2004 gto
    408 E85 GT47-91 ,turbo 400,9" currie straight axle,28/10.5w mt et streets
    2005 yellowjacket gto
    417 rwhp and 397 torque
    582 rwhp and 676 torque (150 shot)
    Jul 2005
    i wanted to try the 99 operating system.
    my settings are 3, 3 and yes. i have a lt1 dash cause the car is a 97. so i believe you have to set the tach to read as a 4 cylinder to read correctly
    Jun 2007
    Ahh yes overlooked that. What settings did you have in it before you switched the pcm. I guess switch the pcm's back and see if the tach works would be the easiest check. Why didn't you just reflash the other pcm with a 99 os? I guess I've never done a lt1 car swap so I'm not sure.
    Jul 2005
    so i hooked up my other pcm...tach works fine....put the 99 back in.....the tach lifts up when you turn the key and starts to read when cranking, once the motor starts its back to 0.
    i have the same settings under the tach area for both tunes
    also to flash the new operating system, do you just go to flash and program pcm op sys and cal?
    thanks
    Jun 2007
    I just had a bad 01 pcm so it kinda sounds you have the same problem. For a NEW OS look at the tutorial. Flash the 99 pcm with the 01 cals and see if the tach works would be another way to test this.
  1. S10 ZR2 and Tach
    By ZR2_350 in forum Vortec V6/V8 Specific
    Last Post: June 17th, 2009, 06:40 AM
  2. E38 Tach
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: June 11th, 2009, 05:50 PM
  3. E-38 Tach output
    By MSURacing in forum Gen IV V8 Specific
    Last Post: February 10th, 2009, 06:45 AM
  4. LS1 PCM differences in tach output (F-body vs 04 GTO)
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2008, 03:47 AM
  5. Speedo and Tach OFF
    By 00RAPTOR in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2007, 06:51 AM
