I've done a lot of post searching here and at LS1tech, it appears the jury is still out on whether you need to adjust the effective area for a 90MM TB.
I see a lot that says it helped, and other say it doesn't matter just do the RAFIG leaving the effective area alone and it won't matter. I'm guessing it would make sense to adjust the effective area setting and then do RAFIG. Upon searching it appears the # to set it at is .0320
It also appears most of the talk was C5 related, but TB size is TB size. it appears it's beneficial to both ETC C5 and F body cable driven, just different tables.
Any opinions on this?
