Originally Posted by
pauly24
Yes thank you for the reply.
But there is some conflicting information here, you say
"If you set the HO table high, say 40 degrees everywhere, then the engine will constantly go thru this:
- knock detected,
- PCM applies knock retard and moves octane scaler toward LO,
- KR is ramped out, OS is moved back toward HO,
- knock detected, repeat.
i.e. engine is continually driven to knock."
So this means the only time that you wont experience knock is when your running 98 ron fuel.
If you run 95 or 92 ron fuel your engine is continually driven to knock then from factory. So it can't be bad, the system in place to pull timing must be robust enough to not cause damage then.
