Results 1 to 2 of 2
Thread: 402 ci motor
    Feb 2005
    Default 402 ci motor
    When changing to a 402 from 346 motor. I need to change the cylinder volume. I believe the VE table will need to be multiplied by the same factor as the cylinder volume. Is this correct? Anything else need to be changed?
    Yes that is correct about changing the VE table.
    Use (402-346)/346*100 = 16.185% as the % adjustment for the VE table.
    Off the top of my head, I don't know of anything else you would need to change.
  1. How do you identify which motor in a 04
    By board350 in forum Duramax LB7
    Last Post: October 27th, 2010, 11:23 AM
  2. motor swap
    By OrangeFlash05 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 4th, 2009, 07:53 AM
  3. LS1 to LS2 motor change
    By billiardcue in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2007, 09:14 AM
  4. gen 1 motor with gen 3 ecu
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: January 14th, 2006, 01:27 AM
