Results 1 to 6 of 6
Thread: 4L80-E 3/2 shift solenoid
    Apr 2010
    Default 4L80-E 3/2 shift solenoid
    Does anyone know what the 3/2 Down solenoid in a 4L80-e does or if it can be ignored and left out?
    I got a transmission from a '95 and am getting ready to put it into a '92 that already has a 4L80-e in it. However the connectors are different. I've searched the diagrams and found, besides the wires being in different pins, that the only difference in the wiring is the 3/2 down shift solenoid.
    However it is not on any of the fluid control schematics, or in the main wiring schematics. I can only find it if I look at the full vehicle wiring diagrams.
    Anyone dealt with this or programmed around it for any use?
    2006 K2500 CC LB LBZ Diesel
    Dec 2008
    4L80E has no 3-2 shift solenoid, never did.
    Apr 2010
    That wouldn't surprise me a bit, but why is it in the diagrams?
    Dec 2008
    Quote Originally Posted by ZigBlazer View Post
    Probably a 4L60E diagram
    Apr 2010
    The one diagram is a multi-coverage diagram. It covers the 4L60 and the 4L70 as well as the 4L80. I guess it won't be a problem.
    Default Note
    The 4L60E 3-2 solenoid is not shift solenoid;
    the 4L60E HMTG calls it 3-2 control solenoid;
    it controls the 3rd accumulator fluid exit rate, so controlling the apply rate of the 2nd servo (which applies the band in 2nd gear);
    the 4L80E does not have this solenoid.
    this solenoid is specific to the 4L60E/4L65E/4L70E;
    it appears that GM has eliminated it in some of the later 4L65E/4L70E models.
  1. Curious about Allison 6 speed solenoid logging
    By Brian1 in forum Black Box Logging
    Last Post: October 20th, 2009, 01:15 PM
  2. 4L80 wiring
    By ebayer5 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 6th, 2009, 12:24 AM
  3. Solenoid differences
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: February 8th, 2009, 11:52 AM
  4. 4L80 question
    By Dirk Diggler in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 12th, 2006, 01:17 AM
  5. EVAP vent solenoid
    By PSWired in forum General
    Last Post: June 6th, 2005, 11:03 AM
