What is the factory LMM MAP capable of reading ??
Anybody know what the MAX pressure the stock MAP is capable of reading ??
Should be 52ish PSIA.
vs PSIG ??
I would think that PSIA and PSIG would be the same in this case.
I thought PSIA = PSIG + BARO
anywhere where BARO is zero will allow PSIA to equal PSIG.
So what do you do if you want to run 80 PSIG ??
I'm not sure if this is directed at me or bballer, but a vacuum is a lack of atmospheric or barometric pressure.
Get an aftermarket gauge. There have been a couple of people who have worked with replacement sensors that are good up to 100 PSIA and rescaling the sensor, but last I heard they were having problems with it. It was also on LB7 and LLY motors. I don't think LBZ and LMM motors have access to the boost sensor scaling in EFILive.
I was questioning bballer and affirming your reference to space (PSIA = PSIG = BARO = 0).
PSIA and PSIG are generally defined to be related by PSIA = PSIG + BARO
(nevermind me, I'm just sweeping thru all the threads)
So has anyone explained why MAP isn't equal to BARO at sea level (I'm curious to know)...?
