Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: MAP sensor calibration
  1. #21
    Jan 2008
    Quote Originally Posted by bballer182 View Post
    I would think that PSIA and PSIG would be the same in this case.
    I thought PSIA = PSIG + BARO
    anywhere where BARO is zero will allow PSIA to equal PSIG.
    Boy i was tired when i posted that... Duh PSIG = PSIA - BARO
    note to self... don't post when you wake up
  2. #22
    Jan 2008
    I was questioning bballer and affirming your reference to space (PSIA = PSIG = BARO = 0).
    PSIA and PSIG are generally defined to be related by PSIA = PSIG + BARO
    (nevermind me, I'm just sweeping thru all the threads)
    So has anyone explained why MAP isn't equal to BARO at sea level (I'm curious to know)...?
    Isn't MAP (Manifold Absolute Pressure) supposed to be the same as BARO with zero boost and then as boost rises it reads PSIA? PSIG+BARO??
  3. #23
    Feb 2007
    Yes it is. I haven't played with the MAP PID much, but I know the Boost2_DMA PID matches.
  4. #24
    See post #1:
    Quote Originally Posted by killerbee View Post
    Has anyone else an opinion on what the problem is here?
    At or near seal level, MAP and Baro should be equal. I have noticed idle (no boost) MAP is around 12.0 psi, instead of the expected 14.x psi. Location error, or calibration issue?
    This has been observed on multiple LMM's.
  5. #25
    Jan 2008
    I was just saying that no matter what altitude MAP should equal BARO
  6. #26
    Nov 2007
    See post #1:
    It's simple there is a vacuum for some reason I don't know.
  7. #27
    Jan 2008
    could it be that the intake butterfly is closed during this anomaly?
  1. E38 fuel level sensor calibration
    By harascho in forum E37, E38 & E67 PFI ECM's
    Last Post: November 29th, 2009, 03:39 PM
  2. AutoVE MAF sensor calibration
    By Ritch in forum Gen III V8 Specific
    Last Post: June 21st, 2007, 10:33 AM
  3. New pcv - knock sensor calibration?
    By voda1 in forum Gen III V8 Specific
    Last Post: June 1st, 2007, 08:42 AM
  4. Which MAP Sensor?
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2005, 09:01 AM
