this is a 64 impala swapped with 04 GTO LS1 & 4L60E. @ WOT in 2nd gear, timing is retarded down to 0-4 degrees, knocking ALL the power out of it. All ABS & traction control stuff are gone, I believe it may have something to do with that. How do I make it stop retarding? It will not do it in first gear nor Drive, but consistently in 2nd gear. Timing goes from 23 @ WOT immediately down to 0-4 degrees at 3500-3600. I can't find anything that correlates exactly to that. Thanks in advance
