Is it possible to pull a DSP5 tune out of a PCM ??
Not on a bosch truck (LBZ/LMM), But you can on the LLY/LB7
Doesn't the LB7 have a Bosch PCM on the right valve cover
No, LB7/LLYs are Delphi based ECMs. 06 LLYs are a Bosch LBZ ECM IIRC, oddball of the group.
What is that box just under the intake air tube ?
Thats an ECM if Im not mistaken, Ive only ever worked on a 04.5 LLY where the ECM was mounted to the frame on the drivers side, near the AC compressor. So thats either an 06 LLY, LBZ, or LMM (dont know where the LBZ/LMMs ECMs are located though).
No thats the FICM the ECM in in the same area on all the trucks
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
What is the FICM ??
Hmmm didnt know that, I was wiring a DSP5 switch up for a friend but Im pretty sure that the LLYs dont have that...
I would guess that FICM = Fuel Injection Control Module?
Makes sense the ECM's in the same place, I was a little confused when I thought GM moved it to the engine of all places?!
Correct Fuel Injection Control Module
