Results 1 to 2 of 2
Thread: Wiring NGK Powerdex AFX to the V1 scan tool
    Oct 2005
    Default Wiring NGK Powerdex AFX to the V1 scan tool
    Does the V1 need to be grounded from pin D?
    The Powerdex has 2 analog wires - 1 for the analog device and 1 for a analog ground. Instruction further state that the analog ground must end at the same place as the controller ground.
    method 1
    Analog grd wire from Powedex to V1-pin D plus another wire from pin D to Powerdex ctrl grd
    method 2
    grd wire from V1 pin D to Powerdex ctrl grd
    method 3
    no wire from V1 pin D
    97 Vette 6spd, CamMotion Titan2 LS1 cam, TSP 5.3 StageII heads, Vararam intake, Z06 manifold, ARH headers/cats, Z06 catback, Monster Stage2 clutch, 04 Z06 pcv, new style knock sensor(late98 to 04).
    Using FlashScan V1 with NGK-AFX Wide band
    V1 pin D must be connected to the analog ground.
    So try method 1.
  1. Tuning tool not following scan tool (VE table)
    By dvx in forum General (Petrol, Gas, Ethanol)
    Last Post: October 19th, 2008, 09:43 AM
  2. Scan tool match tune tool?
    By zapp168 in forum Gen III V8 Specific
    Last Post: March 20th, 2008, 05:27 AM
  3. Replies: 4
    Last Post: January 6th, 2008, 11:47 AM
  4. Fit to Scan Tool/Tune Tool
    By limited cv8r in forum General
    Last Post: March 3rd, 2007, 06:10 AM
