Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: cam tuning question
Hybrid View
    Jun 2010
    Default cam tuning question
    Ok so i just got my TSP 220/220 .581/.581 112 LSA cam in my truck and i had my tune updated by my tuner and im doing some fine tunning myselft.
    my question is, if i put in gear and let off the brake it will slowly accelerate till ~1200 rpm and 20mph. What is causing this? my idle is set to 650rpm.
    Also if im cruising along at like 30mph and i let off the gas, its like on cruise and it will stay at a constant speed for awhile before it starts deceleration very slowly.
    I have searched and i think it may be the desired airflow is too high, but im not 100% sure.
    Apr 2007
    If Idle airflow is to high you will get this,and also look at your throttle cracker!!
    Jun 2007
    Throttle cracker is most likely the culprit but ve can effect this also. But it would have to be wayyyy off.
    cosmos purple 2004 gto
    408 E85 GT47-91 ,turbo 400,9" currie straight axle,28/10.5w mt et streets
    2005 yellowjacket gto
    417 rwhp and 397 torque
    582 rwhp and 676 torque (150 shot)
    Jun 2010
    its probly the throttle cracker, ill have to check that out.
    should i just decrease the table by a few percent?
    Oct 2006
    Desired airflow in gear sounds like it is too high from the symptom you first describe as well as TC.
    The Tremor at AIR
    Jun 2007
    Yes start with that. Desired airflow may also be too high as ute said. I forget about that table sometimes.
    Just bring it down by a small %. Or attach your file and someone can take a look to see where it's at and possibly help you out.
    Jun 2010
    i decreased the desired airflow a tad bit. it seemed to help a faint bit.
    here is my tune file.
    Jun 2007
    your throttle cracker air flow is very high. Might want to find the oem values and try them.
    Jun 2010
    i have my previous tune before the cracker was adjusted....ill try putting those values in place of my current ones and see if that helps.
    thanks
    Jun 2010
    well i looked at my tune before cam and after and the throttle cracker values are the same.
    the throttle follower has been changed though.
  1. E40 idle tuning with cam
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: October 25th, 2009, 07:31 AM
  2. tuning for new cam
    Last Post: April 26th, 2009, 11:18 AM
  3. Idle question With Cam, etc and VE Table
    By Chalky in forum Gen III V8 Specific
    Last Post: September 12th, 2007, 01:28 AM
  4. help with tuning AC with big cam
    By 01blkss in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2006, 01:48 PM
  5. A question for you head and cam guys.
    By johnsZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2006, 07:12 AM
