Results 1 to 10 of 14
Thread: Ok Here is my first Log, what do you see and any recommendations?
    Jun 2010
    Default Ok Here is my first Log, what do you see and any recommendations?
    First off, thank you for every ones help. I have come to realize there is nothing wrong with asking for help when trying to learn something. I apologize for my "newness" the the tuning world, but we all have to start at some point. I just received my EFI Live a few days ago, and I have been browsing the tutorials and what have you. So I decided to follow the scan tool tutorial and Log for the first time.
    So this is a WOT pull with my 2004 Z06. Only mods are CAI, Mufflers and TB bypass.
    WOT2.efi
    For someone who is just getting their feet wet, please make some recommendations. I appreciate it.
    I'm glad you posted... no need to apologize (everyone is new at one time or other)...
    I'm running late at the moment, but I linked this in my todo's so I'll look alter tonite... in the meantime I'm sure others will take a look and give you comments/hints.
    Jul 2008
    Dogg:
    Generally looks good. You have a pretty fast car, judging by your VSS's (mph).
    A few notes:
    1. Looks like you are running Closed-Loop, MAF-enabled?
    2. No KR noted.
    3. Your LTFT Trims are high. Thats normal with a cold air intake, but will need adjusting.
    4. Your Narrowband O2 mv look good.
    5. Spark Advance looks good.
    6. You are getting close to maxing out your injectors. That may get 'better' as you get rid of those +LTFT's, disable COTP fueling, lean out PE etc..
    7. Whats your Rev limiter set at? I like the 6801 Rpm's !
    Overall, not getting KR and having good acceleration is a plus. You are a good candidate for WeathermanShawn's Tuning Tutorial ( I don't get paid for this....)...http://download.efilive.com/Tutorials/PDF/Calc.VE Tuning Tutorial.pdf
    You have a nice ride. A wideband, some fueling adjustments..you are on your way..
    Jun 2010
    Hey thanks! I have a wideband, I just haven't installed it. Actually I am a bit confused on the wideband, my goal is to tune other peoples/customers cars as well, so I was wondering if I could just use the primary 02 sensor location for the WB and just remove the WB when I am done?
    It is running CL with MAF enabled because I haven't touched anything yet. I just wanted to attempt to Log and be successful at that. Woot! Step one is done. Ha
    No knock retard noted, is that good?
    LTFT being high, what is the norm? What are some ways to adjust and what is safe?
    Any idea what size the stock injectors are? Would there be any reason to replace them?
    Rev Limit on the Z06 is 7k I believe.
    Lookin forward to WeathermanShawn's Tutorial. I'm done with the scan tool tutorial, but I'm not sure if I am ready to make any adjustments yet. I think I will go through the tune tool tutorial next.
    Thanks for your reply!
    Jul 2008
    Quote Originally Posted by n8dogg View Post
    I think others have done that. On my car I use both banks for tuning, but my wideband bung (header location) is very close to the narrowband.
    Good job!
    YES!!! Keep it that way..
    Normally, you want them close to zero or slightly negative. In my Tutorial I cover a lot of that. If you are keeping MAF, he easiest way is to 'calibrate' the MAF Calibration Table in your tune. Positive Fuel Trims add excess fuel at WOT or when engaging PE.
    I think the ZO6 were ~30lb'ers. Probably no need to replace. You hit 6800 Rpm, and still had room. With some additional tuning, you should be fine.
    Nice..
    Thats a good step. When you are ready to do some adjusting, just post your tune and another log. I like to think you can do the above Tutorial in an afternoon.
    Your welcome..
    Good luck..
    Good log.
    Log these pids:
    VSS
    TP
    RPM
    DYNCYLAIR_DMA <-- From VE, lets you index into spark tables.
    CYLAIR_DMA <-- From MAF, lets you index into spark tables.
    MAF (SAE)
    MAP (SAE)
    DYNAIRTMP_DMA <-- lets you see what IAT/ECT blend the PCM used, allows computing VE.
    IAT
    ECT
    EQIVRATIO or AFR
    SPARKADV
    KR
    LONGFT1
    LONGFT2
    HO2S11
    HO2S21
    MFTOTAL
    CALC.CYLAIR
    Keeping the pid channel count no greater than 24 yields the fastest sample rate.
    Which wideband do you have...?
    Do you have FlashScan V1 or V2...?
    Jun 2010
    Good log.
    Log these pids:
    VSS
    TP
    RPM
    MAF (SAE)
    MAP (SAE)
    IAT
    ECT
    EQIVRATIO or AFR
    SPARKADV
    KR
    LONGFT1
    LONGFT2
    HO2S11
    HO2S21
    MFTOTAL
    CALC.CYLAIR
    Thanks, I couldn't find a good guideline of PIDs to Log for Tables.
    I'm at work now, I will surely check all of these out either on lunch or when I get home.
    I just got it, so I believe it is V2 and the wideband is the LC-1. Is it necessary to use the wideband on a fairly stock car for making just minor adjustments?
    Wideband will reveal how close the factory tune is... and for making any fueling changes a wideband is a very big advantage.
    If your FlashScan has the LCD then it's a V2.
    See these links:
    showthread.php?8858-Tutorial-FlashScan-V2-Serial-Wideband-Logging <-- see his sig.
    showthread.php?9340-serial-port-cable-that-goes-to-v2 <-- see post #3.
  1. New log. What next?
    By sinr98 in forum Gen III V8 Specific
    Last Post: November 4th, 2009, 07:38 PM
  2. This is my log. What next?
    Last Post: October 24th, 2009, 04:06 PM
  3. Oil Pressure Sending Unit - Recommendations?
    By Johnnydangerously in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2009, 03:37 AM
  4. Can you look at my Log
    By SRT10KLLR in forum Gen III V8 Specific
    Last Post: November 11th, 2008, 08:44 AM
  5. How can I log
    By Rusty in forum Gen III V8 Specific
    Last Post: December 29th, 2006, 01:53 AM
