Results 1 to 10 of 17
Thread: In Which MAP/RPM should the AFR will be less than 14.63 (stoic) ?
    May 2010
    Default In Which MAP/RPM should the AFR will be less than 14.63 (stoic) ?
    I'm in the process of tuning my VE table i want to know MAP/RPM should the AFR will be less than 14.63 (stoic)
    i know in the high MAP 90-105 it should be 12.8 max for N/A cars but what about the area 3500-4500 RPM in the 75-85 map ?? what is the ideal AFR for it ?
    EFILive Tuner
    i'm using
    14.05 75kpa 3600 - 4800
    13.59 80kpa 3600 - 4800
    13.00 85kpa 3600 - 4800
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    May 2010
    Quote Originally Posted by gmperformancecentre View Post
    i'm using
    Do you mean you try to reach those values using VE or those the commanded values ?
    sorry for this question i'm new in this field
    EFILive Tuner
    Jul 2008
    Whats wrong with the Commanded AFR's in the AUTOVE Tutorial?..http://download.efilive.com/Tutorials/PDF/AutoVE Tuning Tutorial.pdf
    commanded afr's
    this is with EFILIVE'S OS5 Custom OS
Name:	ScreenHunter_01 Jun. 07 21.04.jpg
ID:	8172   Click image for larger version.
Name:	ScreenHunter_02 Jun. 07 21.05.jpg
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Oct 2005
    Wesam what operating system are you using for the tune?
    97 Vette 6spd, CamMotion Titan2 LS1 cam, TSP 5.3 StageII heads, Vararam intake, Z06 manifold, ARH headers/cats, Z06 catback, Monster Stage2 clutch, 04 Z06 pcv, new style knock sensor(late98 to 04).
    Using FlashScan V1 with NGK-AFX Wide band
    May 2010
    Operatin system 01250001
    OS ID V1
    Checksum $0E98
    EFILive Tuner
    Oct 2005
    If the ECM is using the richer of VE or CFOL - the problem is figuring exactly which table is providing the AFR. Does the VE BEN 'ONLY' pickup a value when the AFR is coming 'FROM' the VE table? If so, could one do a BEN map for CFOL table?
    Jul 2008
    Quote Originally Posted by voda1 View Post
    The VE will give you the amount of airmass needed for a particular AFR/EQ. The 'CFOL' is simply a multiplier of that airmass.
    I am sure someone can explain it better than I can. But, if you are solely following the AUTOVE Tutorial, you must successfully follow the instructions to map out your 'VE Table. That determines your airmass for that particular EQ. The CFOL is just an EQ multiplier to the VE Table. It 'looks' to the VE Table for the airmass and then applies the EQ multiplier you have chosen.
    From Joecar:
    Wideband reports the same AFR as commanded AFR if these are all true:
    1. B4001 and injector tables are correct,
    2. When PCM uses VE: B0101 is correct,
    3. When/if PCM uses MAF: B5001 is correct,
    PCM calculates airmass from:
    - above B0120: MAF,
    - below B0120: MAF (steady throttle/airflow) and/or VE (transient throttle/airflow),
    - in SD (MAF-less): VE.
    PCM determines AFR from:
    - CL: closed loop feedback trimming to stoichiometric AFR (B3601),
    - OL: the richer of: B3605, B3647 (COS), and B3618 (if PE has enabled from B3608-B3616).
    The various protection mode AFR's are reflected in the commanded AFR.
    The PCM selects the richest AFR from the AFR tables active at that moment.
    PCM uses OL when:
    - cold,
    - at WOT,
    - in PE,
    - during throttle/airflow transients,
    - CL is disabled.
    VE/MAF determine airmass.
    OL/CL determine commanded AFR.
    SD/MAF are orthogonal to OL/CL (there exists 4 combinations of these).
    PCM also uses airmass to determine ignition timing and transmission pressure.
    Make sense?
    As was said above:
    VE provides cylinder airmass.
    Richer of CFOL and/or PE (if PE enabled) provides commanded AFR.
