Results 1 to 5 of 5
Thread: No O2 signal after starting! Does work before starting! Heaters work with ignition on
    Jun 2010
    Default No O2 signal after starting! Does work before starting! Heaters work with ignition on
    I posted this question on another forum to no avail. Here are a few excerpts of my posts but no one had ever seen this before and did not give sure answers. The local tuning shop is using EFI live for the tuning with OS 3. I am not really experienced with tuning but I can contact the shop for any tune details that may be needed to solve this dilema. Basically the o2's work on a cold engine with the key on, once the motor is started they stop responding. The wiring is guaranteed to be correct, I personally built the harness and it has been verified by others.
    Engine Specs:
    408 ci ls1
    Siemens 60 lb/hr injectors
    Speed Density tune
    4l65e auto trans
    no vats/rear o2/emissions
    Post #1
    I could write a novel on how these o2 sensors have driven me crazy. I have a 408 ls1 stroker in a 1950
    Chevy truck and have deleted all emission items and rear o2 sensors. I have had a local professional tuner come to my house for the third time to baseline tune my truck so I can break-in the new motor and trans before it goes to be dyno'd. The truck runs and all sensors have signal input to the PCM. The o2 sensors flatline at 450 mV. So I swapped the sensors, same result. Then I completely removed the 02 sensor wiring and put in a new o2 sensor harness with its own dedicated ground and ignition power. This morning we plugged a TECH II scanner into the truck and turned the ignition on. We got a signal: 300mv, 700mv, moving around, and so on. He wrote a new OS (Efi-Live System #3 ?) and started it. The same result, no o2 signal, flatline at 450 mV. I am desparate here, this has kept me from about 3 months of car shows and I just want to drive my truck. We did try swapping PCM's but it made no difference. Any help would be appreciated. Questions are welcome if I need to be more specific. Thanks!
    Post #2
    When the engine was cool, I did not have a scan tool available to me te other day, but I put a multimeter on the purple signal wire and it went above 700 mV when I turned the ignition on. Then this morning we turned the ignition on (cold engine) with a TECH II plugged in and it confirmed that it had a signal. Once we got the engine running, EFI Live showed 450 mV and the TECH II confirmed that.
    Post #3
    I just did the "manual" o2 heater test by removing them from the pipes and feeling them with the key on. In about 30 seconds, they were very hot. Both sensors responded the same way. To answer the question about the o2 to PCM wiring, I replaced both purple and tan wires all the way to the PCM and crimped new pins on the end. The o2 wiring is completely new. Keep the comments rolling in, believe me, I really appreciate every single comment.
    Jul 2008
    There are so many elements to this problem.
    Somehow, all I can think of it that in deleting the rear O2's (in the tune), the fronts may have also been set to 'Not Reported', or 'Emissions'. If the MIL was turned off..it might be hard to diagnose.
    It would be interesting to see your DTC Scan with every MIL and Processing Enabler set back to stock.
    Thats all I got...
    50chevy, welcome to the forum...
    If you can, please post your PCM file and any logs you have.
    Are you certain that the O2 sensors are not cross-connected (e.g. not connected left-right swapped or front-back swapped)...?
    Jun 2010
    Thanks for the responses so far. I am contacting my tuner right now to see if he can email me any and all files that that he has for my tune so I can post it here.
    As for the wiring:
    Left: ppl/wht - Blue Pin # 69
    tan/wht - Ble Pin # 29
    Right: ppl - Blue Pin # 66
    tan - Blue Pin # 26
    Heater Circuit works, turned ignition on and they got hot.
    Quote Originally Posted by 50chevy View Post
    tan - Blue Pin # 26
    That looks correct.
  1. scanner buttons work work?
    By pullincrazy88 in forum FlashScan V2
    Last Post: May 16th, 2009, 01:12 PM
  2. Starting up
    By c55asleep in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 25th, 2008, 01:10 PM
  3. Starting OS
    By s10mods in forum Gen III V8 Specific
    Last Post: September 24th, 2007, 06:00 AM
  4. Starting Over
    By lplott in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 19th, 2007, 04:36 AM
  5. Starting at square 1
    By 1morews6 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2005, 08:06 AM
