Results 1 to 3 of 3
Thread: cant shut off low coolant alarm in DIC?
    Jun 2010
    Default cant shut off low coolant alarm in DIC?
    Well the title says it all, I have a Duramax in a SUV and for what ever reason GM has seen fit to wire the "low coolant" switch from the engine coolant resioir into the A/C control modual. Yep you read it right, the A/C head unit. If I swap the diesel dash for the gasser I still get the same alarm so I'm sure its comming from the engine, if I swap the a/c controler out then the alarm goes away but it wont support the rear a/c. Can't find the engine output for the alarm is there any way to get at it.
    Eric
    Apr 2009
    I removed/replaced the factory coolant tank on DMax. I have the same DIC message. I have looked briefly with a SnapOn Solus Pro to see if this message can be deleted and have not found a reset/clear entry for that particular message. Nothing even close in EFI Live from what I've seen thus far. I will be checking again with the Solus this weekend and will let you know if I find anything.
    2007 2wd RCLB LBZ w/6spd Alli
    Extra Air & Fuel
    Still tweaking
    Jun 2010
    Hey Powel, since you just replaced the tank if you used one with a switch it should be o.k. The signal is just a ground return (bk/wh on one side of the NO switch and the return is lt gn) it goes back to the a/c controller of all things, go figure. The return signal goes to pin 14 on the j2 black plug. The only thing I can figure is GM did it to shut down the a/c in a low water condition via hard wire, but it doesn't exist on the gas engine. Seems odd to me.
  1. Programming the DIC
    By Whippled 496 in forum Tips and tricks
    Last Post: December 14th, 2012, 04:44 PM
  2. Add log note option when Alarm is set for BBL
    By Biodiesel66 in forum FlashScan V2 BB Logging
    Last Post: May 3rd, 2010, 07:38 AM
  3. Help dic is @#$%
    By messejme in forum Duramax LLY
    Last Post: September 13th, 2008, 12:58 AM
