Results 1 to 10 of 12
Thread: COS 3 auto VE and boost (reduced engine power")
    Oct 2007
    Default COS 3 auto VE and boost (reduced engine power")
    Im in the process of doing my auto ve with cos 3 and boost ve, while going into boost at a high kpa the truck goes into "reduced engine power" this happened after the first logging session.
    It happens when it hits high boost about 7 lbs, i have raised the etc table by 40%
    Im also on OLSD, any Ideas?
    modsare 6.0 lq4 72lb injectors, t76mm turbo at 7lbs
    tune:
    Apr 2008
    I don't have my software here in front of me, it is easy, go to diagnosing section and increase ( by 50 %) the ETC, MAP values. I will check it for you later.
    Regards,
    Odd Boy
    Oct 2007
    still cant figure it out, i bet it has to do with boost ve table
    Oct 2007
    after searching the forum i found tout that some people have raised ETC by 200% I will try this later on today.
    Apr 2008
    try this file
    By OB.tun
    Regards,
    Odd Boy
    Oct 2007
    will try it in a few!
    Oct 2007
    This worked, thanks!
    Apr 2008
    happy to hear that.....
    Regards,
    Odd Boy
    Good deal...
    Mar 2009
    Quote Originally Posted by odd boy View Post
    Could you tell me what you altered to fix his problem? I am having same issue going into boost. Thanks Thomas
    2004 silverado rcsb 2wd 5.3, 3.42's, 4l80e w/hd-2 and yank 3200, 01 LS6 cam, walbro 255hp intank pump, edge products 60lbs injectors, sts rear mount, EFILIVE with help of Nelsonperformance.
  1. switched from COS 3 to COS 5 now reduced power mode
    By CRU SS N in forum Custom Operating Systems
    Last Post: April 26th, 2010, 04:48 PM
  2. P1514 Reduced Engine Power.
    By Mort in forum Gen III V8 Specific
    Last Post: April 2nd, 2009, 12:51 PM
  3. Reduced engine power
    By redlinepd in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 7th, 2007, 08:30 PM
  4. ETC, Reduced Power Mode & Boost
    By GMPX in forum General (Petrol, Gas, Ethanol)
    Last Post: May 31st, 2006, 09:44 AM
  5. Reduced Engine Power while MAFless
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2005, 04:08 AM
