Results 1 to 8 of 8
Thread: Can't pull
    Nov 2007
    Default Can't pull
    I'm having trouble pulling a stock tune from a 05 LLY. I tried it with BBR and FAIL,
    I wasn't sure if BBR was ready for the LLY yet.......so I tried to pull the tune with
    my laptop and FAIL. ??
    Apr 2007
    Can you give more detail where you are failing at? Can you get it to start? Anything?
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Nov 2007
    The truck runs great, as great as stock can be LOL. I just can't read the tune from the ECM ??
    To the best of my knowledge it has never been tuned nor has any cheater boxes (banks, edge)
    What does V2 LCD say when you do this (BBR)...?
    What does the tunetool say when you do this (passthru)...?
    Nov 2007
    The V2 says Error, I don't remember what the number was.
    The tune tool says loss of communication just after the seed is found. I tried 4 times with the software, I checked all connections.
    After two tries I unpluged everything the USB cable the OBD cable and shutdown and restarted the software.
    Oct 2004
    Have you tried pulling the Radio and Info fuses? That is often required on the LLY from what I see...
    Andrew
    EFILive Crew
    Nov 2007
    GOOD to know !! What is the INFO fuse ??
    Aug 2007
    info fuse is for your onstar system.
    2005 chevy silverado, duramax tuned with efilive
    1997 Saturn sc2 turbo, tuned with megasquirt on e85
    2000 s-10 turbo'd tuned with efilive on e85
  1. cant pull the stock file
    By saltflat in forum Vortec V6/V8 Specific
    Last Post: June 2nd, 2009, 02:10 PM
  2. Displacement not on pull down
    By dennisscars in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: May 24th, 2009, 01:15 PM
  3. Help, why can't I pull timing through my AIT?
    By 860 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 6th, 2008, 11:32 AM
  4. What else could pull timing?
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2006, 11:24 PM
