Thread: COS 3 Lean issues under boost
    Oct 2007
    Default COS 3 Lean issues under boost
    Having some lean issues under boost in first gear it starts out around 10.5 afr and it leans out to about 14.5, going around 40mph it does lean out abit to about 12.7afr as you can see in the log.
    i have do the AutoVe its not that close but its getting there
    tune and log
    mods are:
    76mm Turbo
    6.0 lq4
    72lb injectrors
    7psi boost
    walbro 255 intank
    Apr 2008
    post dyno sheet please.
    Regards,
    Odd Boy
    Apr 2008
    If u didn't have it on dyno, you need to consider the following for causing lean:
    1. Weak fuel pump (install pressure gauge and observe it)
    2. Wrong tuning, I will check your file later.
    3. Bends in the fuel system.
    4. Wrong installation of the fuel system, in case of using big fuel pumps with new fuel line.
    5. Small injectors (not applicable for your setup)
    6. Bad MAF sensor incase it is maf tuned.
    Regards,
    Odd Boy
    Apr 2008
    Please fill the below table
    RPM MAP AFR
    2000
    2500
    3000
    3500
    4000
    4500
    5000
    6000
    Regards,
    Odd Boy
    Oct 2007
    i attached the log in the first post. It shows the afr
    Lifetime Member johnv's Avatar
    Jan 2005
    For starters you have too much timing under boost, I see 7 deg knock retard in the log,
    You need to use the boost timing table to pull timing !!
    Your commanding 10.5 AFR in PE , too rich unless your on E85
    aim for 11.5-11.8 AFR
    Your boost VE table has big numbers in the areas your going lean , so i suspect your running out of fuel pump, check fuel pressure under boost.
    Going by your Injector flow rate table you have a boost ref feul regulator (flat instead of sloped table) is that correct ?
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
  1. COS 3 auto VE and boost (reduced engine power")
    By blazinblue in forum Gen III V8 Specific
    Last Post: September 13th, 2010, 03:10 PM
  2. Lean Cold Open Loop AFR Issues
    By SOMhaveit in forum General (Petrol, Gas, Ethanol)
    Last Post: October 24th, 2007, 06:00 PM
  3. COS 04140003 lean problem
    By AGRO in forum Custom Operating Systems
    Last Post: June 23rd, 2007, 11:20 PM
  4. Some boost and VE issues
    By Whippled 496 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 6th, 2007, 02:07 PM
  5. Anyone else running COS on high boost motor?
    By Redline Motorsports in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 29th, 2005, 06:35 PM
