Results 1 to 2 of 2
Thread: How do you get the gauges to go red with the new dash?
    Default How do you get the gauges to go red with the new dash?
    How do you get the gauges to light up red when they reach a maxed value? I never had a problem with the older style dash!
    I went to the alarm setup and thought I could just set the values and be done.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Oct 2003
    The format of the new default dash has the gauges set as 'transparent' so that the cool dash image shows through. If you make the gauge visible, you will see the earlier gauge style appear, and it will turn red if you set the alarm. Same goes for colored ranges on dials.
    Paul, is it possible to enable the colored dial ranges and background alarm colors spearately from the gauge, so that they could be seen on the background image dials?
    cheers
    2003 Silverado SS
    N/A: 14.257 @ 94.63 mph
    N2O: 13.200 @ 102.3 mph
  1. Why can't I add gauges?
    By arubenstein in forum General
    Last Post: March 28th, 2007, 07:24 PM
  2. AEM wideband gauges
    By madprof01 in forum External A/D inputs
    Last Post: June 5th, 2006, 09:34 AM
  3. Where did my Dashboard gauges go?
    By curtbriggs in forum General
    Last Post: February 27th, 2005, 12:11 PM
