Dogg, I forget if you have your wideband or not..
Here are a few tips for you assuming you have a wideband.
1.
B0701 Catalytic Converter Protection Enable: Change to
Disable. This just adds additional fuel during
repeated WOT runs to help cool and protect your cats. It also robs power by adding
too much fuel at WOT. I have cats, and have it disabled. Just stay away from repeated 10-15 second WOT runs.
2. I personally like the Z06 Spark Table. But, if you want to try a more aggressive Spark Table..use a 1998 Camaro LS1 (manual). Just copy and paste it into your tune file..
http:///www.holdencrazy.com/EFILive/stockTunes.php
3. Using wideband set Table
B3618 to 12.7 AFR across the board.
4. Log
LONGFT1 and
LONGFT2 along with
MAFFREQ. That will tell you how much you need to calibrate the MAF to equalize Trims.
I am not sure on disabling CAGS via tune. I did it with a solenoid. But I did disable the Air Pump via tune.
I would offer up my tune, but in all honesty I have made so many changes from stock along with different gearing and modifications..it just would not make sense.
If you are not using a wideband I would only do tip #4. The goal is to safely go leaner on WOT, and see how much spark your can can handle..
Good luck..
