Results 1 to 6 of 6
Thread: shutting down during sled pulling
    Member SGFastMax's Avatar
    Apr 2009
    Default shutting down during sled pulling
    im tuning a customers lb7 that he sled pulls and once it reaches a certain point the engine shuts down or the ecm limits it to 1900 rpm. hes using a different ecm with the same service number and i loaded a 6006 dsp5 os on it. i ran over every table looking for something to cause this and the only thing i thought would do it is the expected maf flow table. but the Expected maf flow enable parameter (B0801) was set to 302 degrees. so excessive maf reading couldnt be causing this could it?
    Apr 2007
    Are you sure the problem is rooted in tuning? Perhaps check the connector and pins on the ecm harness and the two on the engine harness. I have seen a similar diagnoses from a harness/pin problem in these areas.
    Apr 2009
    all plugs and pins were supposedly checked, but not by me. so i dont know
    Nov 2007
    check for overboost codes also. I just maxed out all my limp tables for when i pull. mine was limiting fuel do to MAF and boost codes. I think I also had MAF test set to 302 and it still pulled fuel. I just pulled this weekend with the limp tables maxed and all was good
    '04 LB7, AEM Brute Force HD Intake, 4" into 5" single stack, Kennedy Boost valve, EFILive
    Apr 2009
    Quote Originally Posted by acrider2 View Post
    i noticed that too, but in another table its set to -4 but using air intake temp. so thats what was letting it run the maf tests. but i raisd all limiters and were gonna go from there. thanks
    Apr 2009
    the problem was the maf expected flow being too high.
  1. Locking out gears for sled pulling
    By SGFastMax in forum General (Diesel)
    Last Post: July 6th, 2010, 12:58 PM
  2. sled pulling tune
    By browneflatwork in forum Allison 5 & 6 Speed
    Last Post: November 18th, 2009, 03:42 PM
  3. Need help with backfiring-shutting off
    By 67SS509 in forum Gen III V8 Specific
    Last Post: July 18th, 2009, 01:18 PM
  4. sled pulling tune
    By remington_43040 in forum Allison 5 & 6 Speed
    Last Post: April 15th, 2009, 03:20 PM
