Originally Posted by
Blacky
The firmware in your V2 is 2.06.12, I recommend upgrading to the latest available V2.06.35
Also change the FlashScan cable type settings as follows:
Run the Scan Tool by itself (i.e. without the Tune Tool running)
Select Edit->Properties
Change the Preferred interface cable type to EFILive FlashScan V2.5 (HAPI)
Uncheck "Scan all cable types." (if it is checked)
That won't fix this particular issue, it will just makes things run a little more efficiently.
P.S. Has the PCM been tuned by another tuner? The responses (or lack of them) I see in the blx file look suspiciously like what some tuners have been known to do. They "break" the read/flash options in the PCM making the PCM unresponsive when any attempt to read or flash it are made. If that has been done then the PCM can never be read or flashed again.
Are you able to read the PCM? If so, then the PCM has not been permanently locked in that manner. If it fails o the read as well, please send me that blx file a well.
