Results 1 to 3 of 3
Thread: Can EFI fix this?
    Feb 2010
    Default Can EFI fix this?
    Hey, well, I have a 2007 Colorado with the 3.7l IL5. I need to turn the ABS off, due to a solid axle swap. I can pull the little light out of the dash that turns the light on, but I also need to get rid of the DIC message, ABS FAULT. Can EFI do this for me or do I have to live with this? I am a Duramax EFI Tuner, as well as a Powerstroke SCT Tuner, but I have not ever had to play with the messages on the dash. So, can I or can't I? Thanks
    Jan 2006
    EFI wont be able to turn it off.
    Sorry man, thats bound to be a BCM or EBCM module issue, not ECM/TCM/PCM. Maybe make friends with a dealer tech and see if he can shut it off with a Tech II.
  1. Can't connect to RR fix
    By DrX in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 26th, 2009, 11:31 AM
  2. How can I fix this?
    By odd boy in forum General
    Last Post: June 14th, 2008, 05:28 PM
  3. who to fix RR?
    By Cablebandit in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 27th, 2007, 02:52 PM
  4. Ok I Need a pid Fix
    By FFP in forum Gen IV V8 Specific
    Last Post: August 13th, 2007, 05:26 PM
