Start with this first (bootblock 2.6.03 firware 2.06.35) ok now we can start.
I want load a tune on to the bbl and I load the tune on to he SD card using the EFILive exp. Under the tunning menu there is 3 options. The first one is to down load tune off the truck and second one is to update the tune on the truck. If this is true then why doesn't my tune show up when i select the scecond one. Sorry it's late here and my mind on the way out the door.
Thanks for the help.
