Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Incorrect serial EQ data w/BBL
    Nov 2006
    Thumbs down Incorrect serial EQ data w/BBL
    As you can see here, serial EQ matches analog Lambda ({EXT.AD1}*0.2046)+0.5
    My BEN from EQ ({GM.EQIVRATIO}/{EXT.WO2EQR1}) is off the hook lean because of this.
    Passthru shows correct data tho.
    My first time using BBL in awhile.
    How do I open the .ctd files with the tune.exe?
    LC-1 WBO2
    My LC-1 is on my bench at the moment so I can't test it.
    Which V2 firmware are you using...?
    To open the ctd file you need the later V7.5 build.
    showthread.php?13991-July-03-2010-Pre-release
    Nov 2006
    How did I miss that thread?
    I was using 117 & 97
    Was this a known issue?
    I haven't been around too much lately.
    LC-1 WBO2
    Did that fix the BBL serial lambda/eq swap...?
    Nov 2006
    I don't see any new FW in this update.
    The log is bad I'll need to make a new one.
    LC-1 WBO2
    The firmware stills says 2.6.35 but the date is different.
    Nov 2006
    Thanks Joe.
    LC-1 WBO2
    Nov 2006
    I haven't tried it yet.
    LC-1 WBO2
    Nov 2006
    This is still happening w/new firmware.
    Also I'm having a problem formatting my SD Card.
    I put this thread in the wrong BBL forum too.
    LC-1 WBO2
  1. Motec PLM Serial Data to V2
    By RetroAus in forum FlashScan V2
    Last Post: February 6th, 2016, 12:32 PM
  2. BBL & Serial LC-1
    By L31Sleeper in forum FlashScan V2 BB Logging
    Last Post: January 19th, 2010, 12:01 PM
  3. Do I need a PID to LOG serial data?
    By Chalky in forum FlashScan V2 BB Logging
    Last Post: May 15th, 2008, 11:16 PM
  4. BBL data display/record decimal places
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: March 27th, 2008, 03:46 PM
