Do you want me to move the thread...?
LOL
There is Black Box Logging & FlashScan V2 BB Logging.
It should be in the V2 BB Logging forum but it may not matter as long as Paul know this is going on.
LC-1 WBO2
There are a few incarnations of the 2.06.35 firmware that were used in beta release (which is why the version wasn't incremented). The latest 2.06.35 version is dated 30 June 2010. You can update to this (over an existing 2.06.35 using the Firmware portion of EFILive Explorer.
Try getting these versions (http://forum.efilive.com/showthread....10-Pre-release) and confirming that you have the 30 June firmware.
Not sure this is going to do anything for the LC-1 query, but hopefully should resolve SD card issue which has been worked on a lot recently. I'm not in a position to test with an LC-1 either at the moment :(
Andrew
EFILive Crew
I've got the folders written to the SD Card now.
The EQ reversal is still going on. (FSProgV2_06_35.efw 6/30/2010)
LC-1 WBO2
Yeah, the V2 display is correct but the log is wrong.
IRC this happened before.
I also have issue logging to SD card.
It logs for 5-10 minutes then gives a beep and stops the log.
This also happened before but I forget what the fix was.
LC-1 WBO2
The SD card thing I have only experienced (where it beeps and terminals the log) occurs when the SD Card connection is broken momentarily. I had my V2 sitting in a compartment where it would get bumped with acceleration and/or break application. Since moving the V2 I've never had this happen again
Andrew
EFILive Crew
Finally got this figured out.
With the V7.5 pass-through logging the EQRatio was never transmitted from FlashScan to the PC. Instead the EQRatio PID was calculated from the raw data for the Lambda PID. That meant the software had to invert the raw lambda data to get the actual EQRatio value. When BBLogging was introduced the real EQRatio raw data was transmitted. However it was still being inverted by the V7 software - hence it ended up being the same as lambda for BBL data. You can temporarily fix it for BBL by changing the eqratio definition for the SLOT *UNM-16-913 in sae_generic.txt. Change the "i" (invert) to "/" (divide). However, once you do that, then the EQRatio sent via pass-through logging will be wrong (i.e. not inverted). So choose which one you want to use/see and change the SLOT definition accordingly.
Meanwhile I'm adding a patch that makes that change automatically based on the source of the data (pass-through or BBL).
I'm still having problems logging to SD Card.
This is the same card I've been using for as long as BBl has become available.
Also when I try to open a .ctd with the tune.exe, I select use this program for files like this.
It fails to open the tune.exe but instead scan&tune.
LC-1 WBO2
