Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Torque management in action
  1. #21
    Nov 2005
    The only stacking going on in that trucks is with the bills... LS6 crate motor,MP112 Radix Maggy intercooled, rear end, tires, tires, tires, tires, tires, diffs, tires
    I'm gonna have to get another turbo now.. Fockers
  2. #22
    Junior Member Danville Performance's Avatar
    Better get two just to be on the safe side. Hehehehehe! You should hear it with the dump plate off, sounds like a nascar!
  3. #23
    Nov 2005
    Well I've already got one.. Two will do just fine I'd say
  4. #24
    Some pictures (from my friend's car)... Ouch..!!
ID:	504   Click image for larger version.
ID:	505   Click image for larger version.
ID:	506   Click image for larger version.
  5. #25
    Hey, is there any way I can get a look at this graph again?
    Thanks,
    Andrew
  6. #26
    Andrew,
    The diagrams were lost when the forum went to a new engine.
    The diagram showed that during a gear shift, the spark advance went to something like -5 degrees for about 0.2s and then went back to 25 degrees;
    the point being that torque is reduced only for a very short time;
    the amount of torque reduction is programmable, there are tables for this in the transmission calibration.
  7. #27
    Does TM affect throttle plate opening between shifts on Electronic TB equipped vehicles? The timing drop explains the "pop" that I'm getting between shifts.. but I was wondering about the throttle plate opening/closing. Also.. under partial throttle/boost situations.. the ECM sometimes goes into "reduced power mode". Turning the key off, and then back on again, fixes the problem. This is a turbocharged 4.2 liter (I6) Trailblazer.. Can't wait to get some tuning options!
    Travis
  8. #28
    Sounds just like what happens with the ETC LS1's. Should be fun getting these sorted.
  9. #29
    Oct 2003
    When I had torque reduction enabled, on the track, each shift (an A4), I could see the nose dive down (like a granny-shift) and come back up. It was a tight race, and I barely beat the guy. With TM disabled, the car shifts without this dip, and I often can't tell exactly where it shifted without checking the logs... it's that quick/seamless.
    Though I had a dip, would it REALLY make much difference in ET? I can't say. I just don't run enough to get that statistic nailed down pat. But, trust me, when your car is making excess of 500 RWHP and 700 RWTQ, you can tell the difference when timing is cut like that.
    Keep in mind, I'm also the guy tht's putting his 4L60E back in this week (for the 5th tme in two years).
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
  10. #30
    Sounds like it's time to switch to a 4L80E...
  1. dbw torque management ???
    By Slowrc in forum Gen III V8 Specific
    Last Post: February 25th, 2010, 04:52 PM
  2. Torque Management
    By Black02SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 15th, 2008, 03:38 AM
  3. Torque Management A6 vs MZ6
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: December 28th, 2007, 12:44 PM
  4. torque management
    By snoxracer247 in forum Gen III V8 Specific
    Last Post: December 28th, 2007, 11:33 AM
  5. Torque management, TCS, TCS fast torque loss
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2006, 05:16 AM
