Results 1 to 10 of 10
Thread: Underdrive Pulley & Now A/C Does Not Work at Idle
    Jun 2007
    Default Underdrive Pulley & Now A/C Does Not Work at Idle
    Guys, I have a 2004 Z06 that the A/C was working fine on. I had to take the headers off to get them repaired so I figured, may as well put an underdrive pulley on while it's down.
    Here's the issue: since the install, the A/C is all confused at idle. It can't decide to run or not, I can hear the compressor cycling on and off and the light indiciating the A/C is on/off flickers as the compressor cycles rapidly. When the engine is off idle the A/C is fine.
    I'm seeing differing info as to whether the pulley underdrives the A/C, but the most recent info is that it does underdrive the A/C 10%. Clearly, something changed. I did hook up the A/C gauges and pressure is in the range.
    I need a remedy. Anyone seen this before?
    I did do several searches and didn't see a solution in the threads I found.
    Thanks.
    Oct 2006
    Must be low on freon ?
    If not pressure switch .
    Just a couple of thoughts .
    2006 Trailblazer
    Feb 2006
    Any codes? Including the HVAC module. What does the PCM say about commanded A/C?
    Al
    Jun 2007
    No Codes & not low on refrigerant.
    I just used the scan tool and if I bump spark advance to 32 degrees at idle using BIDI, it works fine. A/C stays on & doesn't cycle frantically. Either the PCM is looking for more torque loss at idle and it's screwing things up or something like that maybe? I hate to just start screwing with parameters without out a clue what I'm doing. I usually know just enough to be dangerous, but not I'm disarmed.
    Jun 2007
    Quote Originally Posted by ChipsByAl View Post
    Al
    No codes. Do you mean A/C compensation Spark or one of the IAC PID's? Haven't logged any of those.
    Jun 2007
    OK. I called SLP & the pulley is underdriving the a/c by 5% or so according to them. That shouldn't be an issue though, because my idle is well above 5% more than oem parameters. However, It has changed the relationship of the a/c compressor relative to the stock crank pulley, so the question is, what effect does spinning the pulley 5% less have that would make some sensor or the PCM send/receive a signal that makes it think the compressor needs to shut down?
    Jul 2010
    What happens if you go back to OEM idle? Does the issue get worse or better?
    Jun 2007
    No change. When idle drops below 1000, the A/C compressor starts cycling on and off rapidly. If it is above 1000, no problem.
    Quote Originally Posted by SOMhaveit View Post
    That sounds like what is happening...
    There are some AC torque loss tables in the calibration (under Idle), maybe try playing with those.
    Jun 2007
    Thanks Joe. For the time being I just set A/C idle to 1050 & doubled the value in B4356 in the 0 to 689 kPa area & it's working fine. Also made sure low side pressure on the A/C is maxed at 35 psi. It's 91 degrees here now & better than 50% humidity.
  1. "Paste & multiply" doesn't work?
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2013, 01:12 PM
  2. idle tuning & airflow
    By ZL1Killa in forum Gen III V8 Specific
    Last Post: October 14th, 2009, 08:47 AM
  3. ac wont work at idle
    By hot-dog in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2009, 04:07 AM
  4. Newb help w/ hanging idle & logging
    By LS1-450 in forum Gen III V8 Specific
    Last Post: April 19th, 2008, 11:15 PM
  5. B5910 & B5956 How do they work?
    By DaddySS in forum Gen III V8 Specific
    Last Post: January 6th, 2008, 10:00 AM
