Results 1 to 2 of 2
Thread: Blue Grey scale block.
    Jan 2005
    Default Blue Grey scale block.
    In tune, Main VE table, I have one rpm and one kPa scale block a bluish grey color, same in Scan, BEN factors table.
    What's this about?
    Thanks, Curt
    99C5, mn6, Vortec T trim, Snow meth injection, AFR 205s, ARP studs,Comp 224*112*+2*.580", YellaTerra RRs, PRC Ti's w/dbls, Supermaxx LTs, No Cats, Corsa Indys, LS6Intk, Hurst, Fikse Aro18"s. Pilot Sports 315/30,265/35, 04ZO6 Shocks Hotchkis bars, EBC YellowStuff pads, SS hoses, LM-1, EFILive, 2002 OS. RPS dual disc Clutch, DTE Strut Brace & output shaft.
    It is probably the data linking between the Scan Tool data and the Tuning Tool calibration table. Load a log file and move the chart inspector to a different frame with a different rpm and MAP. You should see that blue/grey cell change to indicate the cell that matches the data.
    If you select a range of frames in te Scan Tool charts, EFILive highlights all matching cells in the Tuning Tool.
    This data linking and display can be controlle dusing the "PID data links" settings on the [Scanner] tab page of the Properties window in the Tuning Tool software.
    When data is linked you may also get a warning that the Scan Tool data and the Tuning Tool data are from vehicles with a different VIN. That is just a warning for your info and should not be considered a "problem".
  1. 1/6th scale SBC that runs...!!!
    By joecar in forum Lounge
    Last Post: February 19th, 2009, 08:08 AM
  2. VE table scale up by how much?
    By queso in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2007, 12:23 PM
  3. LM-1 AFRs in Scan off the scale.
    By curtbriggs in forum General
    Last Post: December 24th, 2005, 06:25 AM
  4. EFILive V7.3 Pre-Release V_3.11 Blue Box?
    By vetteboy2k in forum General
    Last Post: November 13th, 2005, 08:48 AM
