i've updated to the latest builds and FW and just ran into a problem with my PNY 2GB SD card. I had SD CRC checking set to 'YES'. I could not format the card (I've used this card previously without any problems) nor could I read 'SD Card Info' (I got the Error $040C). When I made SD CRC 'NO' everything worked fine. When I made it 'YES' again it failed.
My 512MB PNY SD card works with SD CRC set to 'YES' or 'NO'.
With the 512MB card the V2 shows SD1 and wth the 2GB card it shows SD2, like it should.
