Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: I hate to be a PIA but same problem?
  1. #11
    Oct 2004
    Well, it was the latest as at that date
    Right now we recommend running the pre-release version:
    - 7.5.6 Build 125
    - 8.1.2 Build 105 (which includes the 2.06.35 firmware)
    If you are already running a version of 2.06.35 you will need to update the firmware using the EFILive Explorer firmware tab (Hapi won't consider it an update as the version is the same).
    Andrew
    EFILive Crew
  2. #12
    May 2010
    I am running 7.5.6 Build 125 and also 8.1.2 Build 105 So Im up to date. Ive been running this new release since it first came out. It worked fine for 5 days then it decided it didnt want to recognize my o/s.
  3. #13
    Quote Originally Posted by slows10 View Post
    So then my firmware date is incorrect then? It says may 3 2010 . It should read June 30 2010.
    Yes.
    But as I asked earlier, if you send me the appropriate blx files it would be much easier for me to help you get this problem sorted out.
  4. #14
    May 2010
    Paul I emailed the blx files to you. You should have them now. Sorry for the delay. Thanks, Keith
  5. #15
    Can you please Email me your .tun file? (send it to support@efilive.com)
    I am going to flash an exact duplicate of your tune in to a PCM here and see if we can duplicate the problem. I've tested flashing on 3 different 4cyl PCM's and they seemed to flash ok.
  6. #16
    May 2010
    just sent the tune file to ross. and sent the upload blx file to paul. Thanks for the help. Keith
  7. #17
    May 2010
    Any updates ross?
  8. #18
    May 2010
    I dont know what to do? I dont think there is anything major wrong with my truck. Ive got a horn relay DTC. I think thats from the Bcm not the Pcm. Also I have an intermittent airbag light on. But no codes show up for it. Ross tells me he flashed my tune into a pcm he has there and it worked 5 times. Does that mean my pcm is bad? Should I buy a new pcm and try that?
  9. #19
    I'm still investigating a possible solution.I should have some more info for you later today.
  10. #20
    May 2010
    Alright, Thanks Keith
  1. PID Problem w/BBB - Asked by Cougar 281 (FRPDES problem)
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 02:02 PM
  2. I hate to post this here, but ...
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: December 29th, 2006, 03:07 PM
  3. Hate to go public but my best laptop won't connect to FS ?!
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: March 1st, 2005, 07:37 AM
