Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Can't Load a File
  1. #11
    Nov 2007
    Here ya go ----> LMM_DSP5.ctd
  2. #12
    Do you have the .tun file...?
  3. #13
    Oct 2004
    I get the same error loading that file. There is definitely something wrong with it. I think you'll have to go back to a previous .tun file and re-save into the .ctd format. If you get the same error again then we'll need to escalate to product development.
    Andrew
    EFILive Crew
  4. #14
    Nov 2007
    Here ya go ----> LMM_DSP5.tun
    With all due respect I wouldn't waste your resources unless I'd tried it over and over.
    I tried it on a PC at work, same result (with a fresh download of the software)
    I even bought Norton AntiVirus 2010 today and everything checks out.
    Thank you for your time.
  5. #15
    Oct 2004
    Are you able to send me (support@efilive.com) the .tun file that you are saving this .ctd from please (the DSP in .tun basically)?
    Andrew
    EFILive Crew
  6. #16
    Nov 2007
    It's at the top of my last post. I can also e-mail it if it helps.
  7. #17
    Oct 2004
    Sorry didn't see it there
    Andrew
    EFILive Crew
  8. #18
    Oct 2004
    OK, so I have exactly the same issue which is good. I have emailed development to have a look at it. The problem is not DSP specific, it occurs with standard LMM files also.
    Andrew
    EFILive Crew
  9. #19
    Nov 2007
    Thank you
    It helps to know I'm not crazy.
  10. #20
    Oct 2004
    It should hopefully be somethign pretty obvious as I know it worked in a previous version. I tested saving an LMM as a .ctd specifically without issue.
    Andrew
    EFILive Crew
  1. Help! trying trying to load tune
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 25th, 2011, 07:10 AM
  2. I somebody emails me a HPTUNERS file, can I load it into a car with my EFILIVE??
    Last Post: March 24th, 2010, 12:01 PM
  3. C.O.S. will not load.
    By Webbs in forum Custom Operating Systems
    Last Post: October 2nd, 2008, 05:59 AM
  4. If I open an HP file from Horists site W/EFILIVE, can I load it right into my pcm??
    Last Post: December 28th, 2005, 09:43 AM
  5. Can't uninstall v7.1.9, and can't load v7.2.2
    By VT2_SS in forum Tutorials
    Last Post: May 12th, 2005, 11:31 AM
