Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: Can't Load a File
  1. #31
    Oct 2004
    The issue is that the function that is being called to save the file as a .ctd formatted file is incorrect. There is no such issue with .tun file formats
    Andrew
    EFILive Crew
  2. #32
    Nov 2007
    So my .tun file is ok right.
  3. #33
    Oct 2004
    Yup, .TUN file should be fine.
    Andrew
    EFILive Crew
  4. #34
    Junior Member Abdulla's Avatar
    Jul 2010
    L31Sleeper, can you check your original stock tune file? open it, click on [Calibration] tab, under {calibration identifiers} you will notice {OS}, check the first digit, is it starting with (1), (2) or (5)?, 2 refers to DSP2, 5 for DSP5. If it is (1) or (2) you will need to full reflash the ECM if (I'm not mistaken) as you will be upgrading the OS itself not the tune, and then you will need to flash again with calibration file. (your tune files are for OS DSP5)
    I think there is a lot of things involved in flashing your ECM, thus it would be better to get "Technically correct" advice from EFILIVE
    My knowledge is limited to some tweaks here and there, therefore I don't see myself in capacity to recommend something unless I'm 100% sure about it, but I always try to offer some opinions to help
    In tuning you don't understand things, you just get used to them
    - 2008 C6-Z51, LS3, Edelbrock E-force SC, Methanol Injection, ZR1 camshaft, B&B catback-R66
    - 2005 Tahoe-Z71, LM7, Bank's CAI, Eaton E-lockers, Rancho 9000 Shocks
    - 1996 Nissan Patrol, LT1 355 home built corvette engine, H&C, valve train upgrade, cloye's HD chain, Elec water pump, MCleod twin clutch, 3" headers & pipe work
    http://forum.efilive.com/image.php?type=sigpic&userid=10859&dateline=127922  8842
  5. #35
    Jul 2010
    Sorry, I couldn't notice that there are some replies while I was writing the above post
  6. #36
    The problem is that the V7 software is creating LMM *.ctd files incorrectly with an LBZ stream tag. That means when it is read back into the V7 software the V7 software treats the file as an LBZ image instead of an LMM image. I am fixing the V7 software to correctly tag LMM files with the LMM stream. The fix will be available in the next release. Until then you won't be able to save LMM files using the *.ctd format from the V7 software.
  1. Help! trying trying to load tune
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 25th, 2011, 07:10 AM
  2. I somebody emails me a HPTUNERS file, can I load it into a car with my EFILIVE??
    Last Post: March 24th, 2010, 12:01 PM
  3. C.O.S. will not load.
    By Webbs in forum Custom Operating Systems
    Last Post: October 2nd, 2008, 05:59 AM
  4. If I open an HP file from Horists site W/EFILIVE, can I load it right into my pcm??
    Last Post: December 28th, 2005, 09:43 AM
  5. Can't uninstall v7.1.9, and can't load v7.2.2
    By VT2_SS in forum Tutorials
    Last Post: May 12th, 2005, 11:31 AM
