My car has done this ever since the tune. I have a comp 228 230 cam and other mods. runs and idles great but here is the problem. Been driving any length of time engine fully warmed up. If I turn the car off like to grab a soda at a store and let it set for a bit then do a hot start it will still run fine and idle, now just as soon as I pull out on the street and by the time I get to second gear under light throttle it will start to miss BAD and the wideband in the car will flatline lean. Step on the throttle harder and it will give a jerk and instantly come out of it. wideband goes back to normal and you can drive the car all day and will be fine. It only does it on a hot start and withing 20 seconds after the start or just long enough to get backed out on the road. Cold start is fine and after it has the fit it will be good to go all day until another hot start. Here is a short log of when it done it. what do you think is happening here?
