Still having the same problem. I checked for air leaks and found none. I then replaced the O2s with GM sensors thinking the Bosch may be the problem. Still the same thing. I have no idea what to do next. I took a log today and at the beginning you can see how one bank is pulling massive fuel and the other is fine. It was doing this but then like always it will level off and run fine. Always happens after a hot start but then is fine after that.
