Results 1 to 10 of 13
Thread: Ever since i did my 98 to 02 pcm conversion i get the following codes.
    Dec 2009
    Exclamation Ever since i did my 98 to 02 pcm conversion i get the following codes.
    its making me nuts.
    p0121 p0102 p0135 p0141 p0155 p0161
    any ideas?
    the tps code i have an idea it can be the throttle position sensor. it should read at .4 when foot is off the gas on idle. but it reads 0% am u correct in assuming it should be at .4?
    please any info would be greatfull. i need these codes off of my pcm its driving me nuts with the ses light on.
    Dec 2009
    i want to update that i checked my fuse engine sensor in the engine bay and it was shot. i swapped it and ill let you guys know tomorrow if it cured my problems.
    Dec 2009
    im still getting the codes. i cleared them but im now getting the codes again after a drive and i turned off and on.
    any help?
    anyone in southern cali that can hlep me. i would be glad to pay $
    Dec 2009
    someone take a look at my tune.
    mods below.
    gm asa cam 226 236 110 lsa
    85mm gm maf
    long tubes catted y
    a4 stalled 3600 underdrive pulley
    fast intake
    ported heads
    can you see if anything in my tune relates to the codes being thrown
    Feb 2006
    What RPM is the engine idling at? Check table C3907. You may need to adjust the TPS sensor if the throttle body is not stock. It should go from 0% to 100% as you go from idle to WOT. The MAF code will set if it is disconnected. The other codes are all O2 heater codes, check the power to the sensors.
    Al
    Dec 2009
    in gear it should idle at 870 warm at operating temp. in park it should be at 860.
    If the fuse was blown, did you find the cause of it... and is it blown again...?
    Send me a pm with your exact location and phone number.
    The O2 heater performance DTC's may be due to a poor ground connection.
    The other two may be due to poor wiring.
    The TP one may also be due to the sanity check table that Al referred to.
  1. Help Doing Fuel Segment Swap for my 98 to 00 PCM Conversion
    By edwardzracing in forum Gen III V8 Specific
    Last Post: May 25th, 2009, 05:09 AM
  2. E-85 Conversion
    By vatman02 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 26th, 2008, 02:53 AM
  3. Need help with a few codes.
    By slopokegtp in forum Gen III V8 Specific
    Last Post: July 27th, 2007, 12:36 PM
  4. PCM conversion question.....
    By Rocketman69 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: June 22nd, 2007, 10:51 AM
  5. o2 codes
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: June 5th, 2005, 07:20 PM
