Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
Thread: Calibration Missing
  1. #21
    Dec 2010
    I am having this same problem on a truck that has never been tuned. Its an lmm and we took off the dpf and he just wanted the codes turned off, so i read the stock data and it said ecm had missing calibration but it completed the read. I still tried to turn codes off and fully reflash it but would not let me. It does not give me the green check mark that says ecm is ok.
  2. #22
    Oct 2004
    Can you please ensure that the software and firmware you have installed is the latest versions? We made an update just a couple of days ago.
    Here are a couple of knowledgebase articles that discuss software and firmware updates:
    - Software
    - Firmware
    Please let us know if you still have issues after installing these releases.
    Andrew
    EFILive Crew
  3. #23
    Dec 2010
    Well my software is up to date but when i went to update my firmware it popped up that the device has previously been upgraded to boot block v2.05.xx or greater. Then it says i have to use efi live explorer what does that mean?
  4. #24
    Oct 2004
    See the Firmware knowledgebase link in my previous post for guidance on updating your FlashScan V2 bootblock and firmware. If you are still running the very old 2.04.x firmware please see the noted document at the bottom of the article.
    Andrew
    EFILive Crew
  5. #25
    Dec 2010
    it does not let me click on efi live control panel icon. I have v7.5.6 build (139)
  6. #26
    Oct 2004
    Try the following so we can work out your firmware version:
    - Connect V2 to your PC
    - Go into the V7.5 Tune Tool
    - Select the 'Help->FlashScan V2 / AutoCal V2 VIN Licensing' menu option
    The firmware version will be shown in one of the text boxes.
    Andrew
    EFILive Crew
  7. #27
    Dec 2010
    Ok i got it to update i will try it on the truck tomorrow and let you know. thanks a lot for your help
  8. #28
    Oct 2004
    No worries, let us know how it goes
    Andrew
    EFILive Crew
  9. #29
    Dec 2010
    well it gives me the green check mark now but now when im reading or flashing either one it gives me an error code 12:56:20.734 failed controller has returned to normal operation. then a 12:56:16.171 unregistered interface some features have been disabled
  10. #30
    Oct 2004
    So your software versions are now 7.5.6 Build 139 and 8.1.2 Build 127, and your bootblock and firmware are 2.07.01 and 2.07.04 respectively?
    Have you tried reading the ECM using the pass-thru functionality of the V8 software?
    Incidentally, this isn't a DSP5 you're trying to read is it (because that is not actually possible)?
    Andrew
    EFILive Crew
  1. calibration missing HELP!
    By 1chevy02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 29th, 2009, 10:10 AM
  2. Invalid or missing calibration
    By Redbone in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 22nd, 2008, 12:32 PM
  3. Missing parameters in calibration???
    By mrrattle in forum E37, E38 & E67 PFI ECM's
    Last Post: February 3rd, 2008, 07:46 PM
  4. Holden VE SSV Missing Calibration 12619077??
    By JezzaB in forum E37, E38 & E67 PFI ECM's
    Last Post: December 18th, 2007, 04:27 PM
  5. Missing calibration toolbar buttons
    By jnorris in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2005, 04:20 PM
