Reckon that might explain the bogging/jerking I feel when I first start off from a dead stop. Figured it was just that I didn't quite remember how to drive a standard (been years, just had the car a week or so) but I suppose KR would do it.
Yea, I wasn't sure if you were just spinning your tires, or if ABS (Traction Control) was kicking in. I say that, because it looks like your Spark dropped to 2.5 degrees....Very odd..
So new NBO2s are first up, or the wideband?
Wow, I really hope it is not truly an either or. Your narrow-bands probably need replacing, but I would opt for a wideband no matter what. At least you will be able to accurately determine your AFR, both at stoich and WOT.
Edit: or is there something I need to do about the KR first? This is with high-grade (93 octane, plus all gas in Dallas County is 10% ethanol)
1. Get Wideband.
2. Get narrowbands.
3. Get LTFT's/AFR accurate.
4. Work on Spark.
