I'm collecting SD Card info to help build a database of cards that do work and cards that don't work (hopefully none) with FlashScan V2.
If you have one or more SD Cards, please insert them into FlashScan V2 and document the settings under the option: F4 Options -> F2 File System -> F4 File System Info -> F3 SD Card Info. Then post the settings to this thread.
The Ver column shows the last character of the 3 character display in the lower left corner of FlashScan's LCD and is one of:
1 = SD V1.0
2 = SD V2.0
H = SD High Capacity Card (always V2.0)
Code:
Name MFG OEM Product Ver Size(MB) Sector(B) Works with FlashScan
Apacer 3 SD SD02G 2 1886 1024 Yes
Canon SDC-32M 1 PA S032B 1 29 512 Yes*
DickSmith 24 ID 128MB 1 119 512 Yes
HSC 4 PD E1213 1 976 512 Yes
HP 2 TM SD02G 1 1946 1024 Yes
Kingmax 19 KG SD512 1 489 512 Yes
Kingston 65 42 SD4GB H 3792 512 Yes
Kingston 2 TM SD02G ? 1876 1024 Yes
Lexar 27 SM 00000 2 1936 1024 Yes
Lexar 40 BE LEXAR 1 1962 1024 Yes
Lexar 40 BE LEXAR H 3830 512 Yes
MyFlash Speedy 29 AD 064MB 1 493 512 Yes
Panasonic 1 PA S512B 1 472 512 Yes
Panasonic 1 PA SP02G 1 1921 1024 Yes
Panasonic 1 PA SP04G H 3780 512 Yes
PNY 2 TM SD512 1 488 512 Yes
PNY 27 SM 00000 2 1928 1024 No (when CRC turned on)
Sandisk 3 SD SD064 1 59 512 Yes
Sandisk 3 SD SD512 1 483 512 Yes
Sandisk 3 SD SD01G 2 968 512 Yes
SanDisk 3 SD SD02G 2 1886 1024 Yes
SanDisk 3 SD SD02G 1 1938 1024 Yes
Silicon Power 49 SP H 3843 512 Yes
* SD Cards less than 64MB cannot be formatted in FlashScan.
They can be formatted using a PC Card reader and then used in FlashScan.
