Results 1 to 7 of 7
Thread: Is it possible to reset the peak/max value on a gauge while logging?
    Jun 2007
    Default Is it possible to reset the peak/max value on a gauge while logging?
    9.8@150 . LQ4 Turbonetics Billet 7575@18psi, 6 speed, non-intercooled with meth. Speed Density, open loop, no PE.
    Oct 2004
    Not in the version 7 software. The Min and Max values are for the entire logged session. In version 8 it will be possible to have the Min and Max needles reset after so many seconds, like you commonly see on TV coverage for rev counters
    Andrew
    EFILive Crew
    Jun 2007
    I find it very useful to look at the peak knock value while I do pulls on the street. If it does show knock I like to reset it and look again during my next pull but that requires starting and stopping the log.
    At first I agreed with what Andrew said, that there was no way to do it. So I took a quick look at how difficult it would be to implement it.
    Tracking through the code, I saw that the min/max and average values are reset whenever a selection is made or canceled.
    Pressing the Shift key cancels a selection in the charts and as a side effect also resets the min, max and average values.
    So that would have to be the easiest "enhancement" I have ever had to make to EFILive.
    Jun 2007
    so tonight I will try hitting the shift key during live logging and see if it works.
    I did just that and it worked for me
    It also works during playback.
  1. 06 LLY Fuel Gauge - empty gauge with 7 gallons left
    By timvan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 5th, 2009, 02:35 PM
  2. Air Fuel Ratio or Timing for Peak Power
    By WeathermanShawn in forum Gen III V8 Specific
    Last Post: September 23rd, 2009, 04:42 AM
  3. Peak Torque Timing
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: April 3rd, 2006, 10:30 AM
  4. Switching to peak and hold.. Anything I should keep in mind?
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: February 20th, 2006, 07:25 AM
