Results 1 to 4 of 4
Thread: 96# injector data?
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    Default 96# injector data?
    Anyone have any good injector data for 96#ers used with a Versafueler driver box? I'm shooting in the dark with nothing to go on and could really use some help...
    Thanks,
    Bret
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    Jan 2008
    Yes, me 2. I haven't been able to find any official injector data from Delphi. It's almost impossible to get a hold of them. Anyway, Jeff from Acceleronics told me to use 1.1 ms for MPW and to use the stock injector offset tables. It seems the big low-z 96 can open as fast as the little 28 high-z.
    2001 Camaro SS
    Built 370 LQ9, Ported 243s, D-1SC 14 psi. 691 rwhp, 643 rwtq
    Best time: 11.6@124 on nitto drags with a 2.1 60'
    "if you're gonna build a time machine into a car, why not do it with some style." Dr. Emmett Brown
    Lifetime Member 06redram's Avatar
    Jan 2011
    Here is what I have excel spread sheet
    Here's a link to "injectors.xls" in my Dropbox:
    http://db.tt/DCdHmh2
    Oct 2005
    1.0 ms offset at 14V seemed to work best for me with that combo. I'm now running Injector Dynamics ID 1000 injectors which are high Z and actually come with full data.
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
  1. How to: Program injector flow data from GPM to ECM using EFILive V2
    By DuramaxPowered in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 31st, 2012, 10:22 PM
  2. Can anyone decode this Greek? (Injector Data)
    By samh_08 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2010, 05:00 PM
  3. Injector Data for return style fuel system
    By minytrker in forum Gen III V8 Specific
    Last Post: November 26th, 2009, 03:36 PM
  4. Injector Data
    Last Post: November 24th, 2009, 07:07 AM
  5. Injector flow rate data.
    By bballer182 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2009, 04:55 PM
