Originally Posted by
Earl H
My external voltage readings, w/o any signal being sent starts off at 3.5V. When I send a signal from my wideband, the A/F values and Voltage values are all over the place and they bear no resemblance to the A/F values showing on my Blitz EBC which has been confirmed to be accurate on the dyno...What could be causing this and how do I fix it?
Not sure what that problem might be.
Firstly: does your WBO2 controller ouput voltage in the range 0..5.0 volts?
Secondly: I have just been retesting A/D black-box logging and it appears that AD1 is not being loaded back into theScan Tool at all, when black-box logging is finished. I haven't finished investigating this "anomally" yet.
So I suggest you set up the AD2 pin for your wide band for the time being. Until I can figure out what is going on with AD1.
The AD2 pin is the pin (in the 3 pin connector) that is closest to the 2 pin connector. The ground is the center pin of the 3 pin connector.
Jut for your reference, in the PID definitions:
AD1's raw value is PRN $F400
AD2's raw value is PRN $F401
EGT's raw value is PRN $F402
See page 93 of the EFILive Scan Tool doc for pinouts.
