Its been 3 years since I really last looked at tuning, since then I've upgraded to an e38 system and toying with just leaving things as is out of the box (other than some compensating PE mode commanded fuel as setup on the dyno).
Currently I have no widebands in the car and no plans to do anything in the short term so for now just logging the status quo. My old LC's are both probably dead now and were as unreliable as a stag party in a brothel
The confusion I am hitting is STFT vs LTFT. If the average cell in the STFT map is showing it pulling fuel why does the LTFT in the same cell appear to be adding in virtually/approximately the same amount as being pulled?
Further when I should be entering PE mode it seems the tune holds on to closed loop. Correct me if wrong but when in PE shouldn't it change to OL-Drive? It does hit OL-Drive but not as instant as I'd expect.
So for a stock tune from the factory it seems to run lean according to my LTFT's but STFT's look pretty good. Of course this is logging with MAF, CL, LTFT's enabled so everything that can interfere is switched on. I just find it hard to believe out of the box VE is causing ltft to add in fuel - is this MAF scaling perhaps? I'm adversed to getting to the VE tuning stage on this one as the powers enough as is and so what if its not optimal. However, I'm altering the exhaust next week so if I'm in positive LTFT now and with better exhaust cfm rates I dont want to be relying too much on trims to keep things right.
tune =
http://www.hermantoothrot.co.uk/car_0001.tun
log =
http://www.hermantoothrot.co.uk/scan1.efi
